have finally got the OK from the maker that they can make one and should be with me in 10-14 days time
its for the later versions 84-95.
will test it on mine just to make sure it will work ok and if all good will be taking it to a few 928 meets.
the alloy plug that usually seizes solid will need to be drilled out first, but this should then fully clean the threads.
certainly not a cheap thing, but if anybody needs their front tow eye threads cleaning was planning on charging a £10 donation to Help for Hero's- as for the calendars back in 2017 + would get a free genuine rubber plug for it.
will update this thread when i have it in my hand :thumbup:
looks good, just need to test it :jumper: :jumper: :jumper:
forgot i had the rear tow eye mount, fits like a nice tight glove :jumper: :jumper:
i did ask the makers could make the drive end a 13mm spanner size nut, but sadly they could not.
front end tow eye test this weekend :jumper:
when i did the SE a few years ago i managed to drill and pick out the alloy plug and could screw the eye in approx 1 turn then it went solid.
less than 5 mins with this tap and it now screws fully in, my guess, for the first time in its life.
corrosion that came out still on the bumper pictured
and found a 1/2" multi hex socket is a perfect fit to fit on the tap + short extension and a 1/2" T bar works a treat :jumper:
now warm beer time and wait for England to kick some Norwegian ass at the football tonight :drink: :drink:
I think the bumper guards are available new as wel[…]
I tested both relays in the car. - 01 works as ex[…]
tow eye tap for the UK
when i did the SE a few years ago i managed to dri[…]
https://carsandbids.com/auctions/30QpGGpL/1992-mer[…]
