have finally got the OK from the maker that they can make one and should be with me in 10-14 days time
its for the later versions 84-95.
will test it on mine just to make sure it will work ok and if all good will be taking it to a few 928 meets.
the alloy plug that usually seizes solid will need to be drilled out first, but this should then fully clean the threads.
certainly not a cheap thing, but if anybody needs their front tow eye threads cleaning was planning on charging a £10 donation to Help for Hero's- as for the calendars back in 2017 + would get a free genuine rubber plug for it.
will update this thread when i have it in my hand :thumbup:
tow eye tap for the UK
have finally got the OK from the maker that they c[…]
Antique S2000
https://i.gyazo.com/9316731312e78d44dbc40f823c5c1[…]
Floor Mats
Well, what did you end up with? Back burned t[…]
cambelt gear puller kit
I don't need this, but I know someone does! Huge, […]
