have finally got the OK from the maker that they can make one and should be with me in 10-14 days time
its for the later versions 84-95.
will test it on mine just to make sure it will work ok and if all good will be taking it to a few 928 meets.
the alloy plug that usually seizes solid will need to be drilled out first, but this should then fully clean the threads.
certainly not a cheap thing, but if anybody needs their front tow eye threads cleaning was planning on charging a £10 donation to Help for Hero's- as for the calendars back in 2017 + would get a free genuine rubber plug for it.
will update this thread when i have it in my hand :thumbup:
looks good, just need to test it :jumper: :jumper: :jumper:
forgot i had the rear tow eye mount, fits like a nice tight glove :jumper: :jumper:
i did ask the makers could make the drive end a 13mm spanner size nut, but sadly they could not.
front end tow eye test this weekend :jumper:
tow eye tap for the UK
forgot i had the rear tow eye mount, fits like a n[…]
Sounds fair, I'll just have ANOTHER one use tool[…]
It's not original. It has no racing history. It […]
PSD flush off the car
finally found somebody working on restoring a 91 m[…]
