Our 1st small batch of billet auto transmission pans are in!
These are CNC cut from 6061 T6 and have 3 times the gasket sealing surface over the factory pans. Gasket is flat Viton (FKM) and is included. We will be starting another production run in the near future as these are already sold. No more bent tabs and leaking gaskets. They will be priced at $825 which is a little higher than a factory pan but much higher quality.
No more butt pucker while gently tightening the transmission pan bolts?
PSD flush off the car
finally found somebody working on restoring a 91 m[…]
The 288 GTO sold for $6,825,000.
No more butt pucker while gently tightening the […]
wt - Porsche
Sounds like the teams wanted a gt4 closer in[…]
