Ok I know some of you might still prefer the old style. I have re-enabled it so to get there do the following:
- Click on your avatar on the upper-right corner
- Select Control Panel
- Select Board Preferences
- Look for "My Board Style", this one is called FLATBOOTS while the old one was called Elegance
You can switch back and forth at your discretion.
Now keep in mind when you go back to the old one there might be some features that are now disabled because they are built into the new template. So by moving backwards you're not just going back to the old board but one that is somewhat less functional.
I keep running into little bugs with this new one. As much as I like it, if things continue we'll go back to "old school" if necessary.
By odurandina
#8422
JDS968 wrote: Mon Aug 17, 2020 11:31 am That's a relief, thank you! New one was hurting my brain.
My brain is bruised and i don't see no avatar to click in some corner of.
i will endeavor to persevere.
By Airkuhl
#8438
odurandina wrote: Mon Aug 17, 2020 2:55 pm
By BeerBurner
#8513
Thanks for the info on how to get back to the previous style. I didn't have a problem with the format on the new one but I couldn't find the "new posts" button which I'd rather have. :)
BB.
By Top Jimmy
#8835
BeerBurner wrote: Mon Aug 17, 2020 6:34 pm Thanks for the info on how to get back to the previous style. I didn't have a problem with the format on the new one but I couldn't find the "new posts" button which I'd rather have. :)
BB.
I think this is the big feature missing from the new one. I switched back, but will go with the new form when that gets sorted out.
-TJ
By tooloud10
#9448
I think people are referring to the "New posts" button that shows a list of threads with new posts in them regardless of which forum they are posted in.
By Top Jimmy
#9457
fpena944 wrote: Thu Aug 20, 2020 10:44 am @Top Jimmy
Take a look below, are you using desktop or mobile?
I use both mobile and desktop. The “first unread” button doesn’t show up on a thread at the top in mobile when using the new style. At least I can’t seem to find it.
-TJ
