By fpena944 - Mon Aug 17, 2020 10:55 am
#8304
Ok I know some of you might still prefer the old style. I have re-enabled it so to get there do the following:
- Click on your avatar on the upper-right corner
- Select Control Panel
- Select Board Preferences
- Look for "My Board Style", this one is called FLATBOOTS while the old one was called Elegance
You can switch back and forth at your discretion.
Now keep in mind when you go back to the old one there might be some features that are now disabled because they are built into the new template. So by moving backwards you're not just going back to the old board but one that is somewhat less functional.
