By ltusler
#345421
Why do links to X show a preview but links to Rumble don't?
ltusler wrote: Mon Jun 22, 2026 5:07 pm Why do links to X show a preview but links to Rumble don't?
The link itself will be accessible but for it to show requires the forum to code to treat it differently. Let me check with the author of this code and see if there's a way I can make Rumble also appear the way X does.
ltusler liked this
Ok I got Rumble to work!
I used my trusty AI tool to create code to render the link as I believe the creator of this theme has gone dark.
In any case here is what you need to do:
- Within the video click NOT on the "share" button but on the three dots to the right of "share"
- Inside of that you'll see "embed code" and "embed iframe URL"
- Copy the "embed iframe URL" to your post and it should show up
Unfortunately I couldn't get it working with the share URL so apologies for the extra step but at least this one does seem to be working properly from my perspective. Test it and let me know if you have success:
By ltusler
#346336
Thanks, but I doubt Harco will do the work.
ltusler wrote: Thu Jul 02, 2026 9:25 pm Thanks, but I doubt Harco will do the work.
Haha yeah I get it. I'll keep trying to see if I can get it to work properly but at least we have a semi-solution.
A couple years ago I scavenged a 1979 junkyard 928[…]
2 years since i built it, ageing nicely and i only[…]
Anyone got a spare rear wheel bearing puller/i[…]
Dreaded Coolant lines
https://i.gyazo.com/b2b219fda69ef011f2ce0fe9b051a[…]
