By hernanca - Tue Jul 08, 2025 12:37 am
#313176
So, I was looking through the K&N site and stumbled across their formula for target "effective filter area":
((Displacement in cubic inches) x
(Max RPM)) / 20839 = effective filtering area
It seems to be based on the desirable CFM for the same Displacement and max RPM (see first attachment).
I measured my 86.5 stock air filter's actual mesh filter portion and came up with 81 square inches (18 * 4.5 inches). I am assuming all 928 filters are the same size? Then I applied the K&N formula to different model year 928's that I could easily find info on. Interesting results (second attachment).
Note that I found different Redline numbers (6200, 6400, 6800) for the stock 5L motors, so I applied the formula using each redline value I found, and also applied that to my "6.5" motor. Also, it is not obvious, but I used the actual Displacement values (e.g., 4474cc for the 4.5L) and converted them to cubic inches Displacement before applying the K&N formula.
Don't know how much difference it might make, but I am a firm believer in "every little bit helps", and also Math. I believe I need additional "effective filter area" for my "6.5" stroker, and am considering cowl induction anyway.
Bottom line, according to the K&N formula, our filters were sized for the original 4.5L and 4.7 engines, but are undersized after that, for the desirable CFM. See attachments.
worf liked this
Carlos Hernandez
Silver 86.5 928 S Automagic
w/ Stroker Motor (in tuning prep)
928OC Charter Member
http://www.928oc.org/
