By worf - Thu Feb 13, 2025 10:50 am
#297698
This is Randy Carter’s former GTS 5-speed.
It was a good car when I discovered the engine swap in late 2023. Probably still is. Maybe slightly better.
The reason I began looking very carefully was that it drove too well to be a GTS engine unless the engine had been already out once.
If you are looking for a 5-speed to drive then look at this one. @linderpat ?
But, it won’t be an investment.
The story in the first comment has some … interpretational variances … shall we say...that go along with some “disappeared” records. But they do not affect the GTS functionally. I’ll fill in a buyer on ‘the rest of the story
https://bringatrailer.com/listing/1993- ... gn_2648441
My 928 Inspection Guide
