By LSHK928 - Wed Jul 24, 2024 7:52 pm
#273974
Attention all 928 Air Conditioning Experts!
Whilst troubleshooting a non-functioning A/C system (88 S4), using all the usual guides an historical threads, here's what I found:
1. PO had a receipt showing new compressor and dryer. They appear new. No mention of any other work done.
2. I discovered one of the wires in the harness from the pressure switch cut off and "substituted" for a new wire back to and disappearing through the firewall.
3. A little DMM work and found a bad freeze switch, and the wire from it to the pressure switch being the one cut.
4. Traced the new mystery wire back to the console and found it spliced into the A/C on-off switch.
5. Checked and repaired "new" wire splices, and A/C started working.
Conclusion is a bad CCU relay and freeze switch caused someone to bypass both, undocumented of course. After further research and wire diagram study, I decided to put a 5 amp fuse in the compressor line from the pressure switch (cheap insurance), and use the A/C (being summer and I just got the car on the road and have other more urgent issues needing attention)
The CCU on this car has a date from June 1985. I'm thinking it may have already been replaced?
The relay is the Gruner 970. The RL posts on the relay fix - on or off-board, are all quite old and show old Radio Shack parts (remember them?) Does anyone have a recommendation for a new "modern" relay replacement - on or off board?
Any other newer fixes out there to this known issue?
Any concern with running this way temporarily (knowing coil-freeze protection is disabled)?
Thanks all for any advice for this 928 newbie...
The "Landshark 928":
1988 928 S4 - Canadian Import
