Dead battery issue.
Posted: Fri Sep 20, 2024 9:36 pm
by N_Jay
After a few weeks out of town, my battery was 100% flat. Not a click, not a glow of a light and needed to use the fuse box terminal to pop thr hood.
I have it on a good charger, and will replace it if it does not come up to full voltage and crank well.
So, what am I in for in terms of programming and software issues?
Re: Dead battery issue.
Posted: Fri Sep 20, 2024 9:59 pm
by XR4Tim
Likely just a bunch of low voltage faults stored and a steering angle sensor calibration fault that will clear once you drive the car in a straight line for a few feet.
Posted: Fri Sep 20, 2024 10:28 pm
by N_Jay
XR4Tim wrote: Fri Sep 20, 2024 9:59 pm Likely just a bunch of low voltage faults stored and a steering angle sensor calibration fault that will clear once you drive the car in a straight line for a few feet.
Thanks.
I usually try to keep a battery on cars with ECUs.
This was so dead my charger would not even start.
I had to parallel a jump box for a few min.
I give it 50/50 that it comes up low standing voltage.
Posted: Sat Sep 21, 2024 10:11 am
by fpena944
N_Jay wrote: Fri Sep 20, 2024 10:28 pm
Thanks.
Any idea how old that battery is?
It's surprising how quickly P-cars drain batteries when not in use.
Posted: Sat Sep 21, 2024 11:23 am
by N_Jay
It is dated 12/20.
Storage and lack of use is hard on a battery.
All new cars drain batteries. Too many computers and to hard to code realy good sleep routines.
Think about that dripping faucet adding uo to hundreds of gallons in a few weeks.
The battery is at 12.6 after coming off the charger, which is a little low.
I like to see 12.7 on an older battery.
But I usually don't start seeing issues till resting voltage gets down to abot 12.4
Posted: Sat Sep 21, 2024 12:18 pm
N_Jay wrote: Fri Sep 20, 2024 9:36 pm So, what am I in for in terms of programming and software issues?
What year and model car?
N_Jay wrote: Sat Sep 21, 2024 11:23 am All new cars drain batteries. Too many computers and to hard to code realy good sleep routines.
Depends.
Posted: Sat Sep 21, 2024 3:47 pm
by N_Jay
worf wrote: Sat Sep 21, 2024 12:18 pm
Depends.
2012 987.2 Cayman Base
Yes, they all drain at different rates, but they all drain a hell of a lot more then pre-computer car.
Posted: Sat Sep 21, 2024 4:04 pm
N_Jay wrote: Sat Sep 21, 2024 3:47 pm
Does the 987 still have the ‘traditional’ fuse/relay panel(s)?
The 9[98][12] did away with most of the relays and added a software-controlled ‘distribution’ box. When those “go to sleep” they really Go To Sleep. As in: single-digit mAh sleep.
In “classic” cars, drain of more than 20-30 mAh is usually a sign of a stuck-on relay, failure of a ‘black-ish’ box connected to the 30 Bus directly, or a wiring problem. The latter usually (IMO) due to thoughtlessly installed aftermarket ‘lectric stuff and/or bad service performance.
The 87+ 928 has 5 to 9 ECUs and one or more ‘black-ish’ boxes (depends upon definition of ECU.) Battery drain is often, wrongly, considered a “design defect” when in reality the drain is something to be fixed.
