N_Jay wrote: ↑Sat Sep 21, 2024 3:47 pm
2012 987.2 Cayman Base
Yes, they all drain at different rates, but they all drain a hell of a lot more then pre-computer car.
Does the 987 still have the ‘traditional’ fuse/relay panel(s)?
The 9[98][12] did away with most of the relays and added a software-controlled ‘distribution’ box. When those “go to sleep” they really Go To Sleep. As in: single-digit mAh sleep.
In “classic” cars, drain of more than 20-30 mAh is usually a sign of a stuck-on relay, failure of a ‘black-ish’ box connected to the 30 Bus directly, or a wiring problem. The latter usually (IMO) due to thoughtlessly installed aftermarket ‘lectric stuff and/or bad service performance.
The 87+ 928 has 5 to 9 ECUs and one or more ‘black-ish’ boxes (depends upon definition of ECU.) Battery drain is often, wrongly, considered a “design defect” when in reality the drain is something to be fixed.
My 928 Inspection Guide
