By Benno - Wed Aug 23, 2023 9:41 pm
#231022
Hoping to get some guidance from those of you in the know. I am preparing to rebuild my early 1992 GTS motor to help address oil ingestion into the combustion chamber. All the research I have done has pointed to the lack of oil drain holes in the GTS pistons as being a major contributor (not the only one). Several experienced engine builders recommend drilling the GTS pistons.
I wanted to get clarity and specificity on how many holes and where to drill them so I could properly advise the machine shop when the time comes.
Here is what a GTS piston looks like. You will note at least 2 blind holes half in/out of the oil groove (third line). I presume there at least 2 more
Here is what an S4 piston looks like. You will note the two holes on the lower skirt. The holes in the oil groove appear to also be blind holes.
Early S4 pistons did not have these lower holes. However, there is a TSB that instructs techs to add them when pistons are removed.
So my question is where to drill holes?
- Do I add the 4-holes in the lower skirt like the TSB suggests?
- Do I drill the blind holes in the oil groove through the piston wall? There seem to be 8 blind holes. This seems to be what 928 engine builders reference doing and it's what is pictured in the JE image below.
FYI: For reference here is a nice piston terminology reference diagram from JE pistons. I had to educate myself on what all the terms mean.
Schocki liked this
