How to go back to the old style - if you prefer it
Posted: Mon Aug 17, 2020 10:55 am
by fpena944
Ok I know some of you might still prefer the old style. I have re-enabled it so to get there do the following:
- Click on your avatar on the upper-right corner
- Select Control Panel
- Select Board Preferences
- Look for "My Board Style", this one is called FLATBOOTS while the old one was called Elegance
You can switch back and forth at your discretion.
Now keep in mind when you go back to the old one there might be some features that are now disabled because they are built into the new template. So by moving backwards you're not just going back to the old board but one that is somewhat less functional.
Re: How to go back to the old style - if you prefer it
Posted: Mon Aug 17, 2020 11:31 am
by JDS968
That's a relief, thank you! New one was hurting my brain.
Posted: Mon Aug 17, 2020 11:57 am
by Kigiin
Thank you, wasn't going to say anything but much prefer "elegance".
Posted: Mon Aug 17, 2020 12:03 pm
by tooloud10
I kinda preferred the previous format, too. I don't have the option to change back under Board Preferences, though.
EDIT: Never mind, it showed up.
Posted: Mon Aug 17, 2020 12:43 pm
by V-Fib
Dark Flatboots........thanks.....perfect for my old eyes........
Posted: Mon Aug 17, 2020 1:10 pm
by fpena944
I keep running into little bugs with this new one. As much as I like it, if things continue we'll go back to "old school" if necessary.
Posted: Mon Aug 17, 2020 1:28 pm
by alex
Nightstalker mode is much more to my liking. Not quite as much contrast as needed for easy reading in the lighter theme.
Posted: Mon Aug 17, 2020 2:55 pm
by odurandina
JDS968 wrote: ↑Mon Aug 17, 2020 11:31 am
My brain is bruised and i don't see no avatar to click in some corner of.
i will endeavor to persevere.
Posted: Mon Aug 17, 2020 3:32 pm
by Airkuhl
odurandina wrote: ↑Mon Aug 17, 2020 2:55 pm
Posted: Mon Aug 17, 2020 6:34 pm
by BeerBurner
Thanks for the info on how to get back to the previous style. I didn't have a problem with the format on the new one but I couldn't find the "new posts" button which I'd rather have. :)
BB.
Posted: Tue Aug 18, 2020 2:32 pm
by Top Jimmy
BeerBurner wrote: ↑Mon Aug 17, 2020 6:34 pm
BB.
I think this is the big feature missing from the new one. I switched back, but will go with the new form when that gets sorted out.
-TJ
Posted: Thu Aug 20, 2020 10:44 am
by fpena944
@Top Jimmy
Take a look below, are you using desktop or mobile?
Posted: Thu Aug 20, 2020 10:46 am
by tooloud10
I think people are referring to the "New posts" button that shows a list of threads with new posts in them regardless of which forum they are posted in.
Posted: Thu Aug 20, 2020 10:59 am
by Top Jimmy
fpena944 wrote: ↑Thu Aug 20, 2020 10:44 am
@Top Jimmy
I use both mobile and desktop. The “first unread” button doesn’t show up on a thread at the top in mobile when using the new style. At least I can’t seem to find it.
-TJ
Posted: Fri Aug 21, 2020 6:25 am
by Voith
Thank you. Old style feels much more home-ish.
