Page 2 of 2
Re: WORF'S (EDIT: ALL OF OUR) ANECDOTES
Posted: Sat Dec 11, 2021 10:20 pm
The Fat Man wrote: ↑Sat Dec 11, 2021 9:36 pm
Was the 'too-long-bolts' CV joint at the transmission or wheel hub side?
Wheel hub.
But the clearance of the hub and the transaxle flange is such that an extra couple of MMs of length is sufficient to cause interference. The main problem here was two day different both lengths required and rather than 6 and 6 there was 5 and 7 and the odd long bolt was on the hub side.
Now that I think about it, I’ll bet the count is 7 and 5 on the other side. (But, that 928 isn’t here anymore.)
Posted: Sun Dec 12, 2021 11:49 am
by maddog2020
worf wrote: ↑Wed Nov 24, 2021 4:00 pm
This one has been fun. Two problems in this picture. The first one can't be effortlessly deduced:
On the early half shafts there are two different sizes of Alan bolts. PET no longer indicates this. In the picture below, there are 7 long bolts and 5 short bolts. The "previous technician" upon discovering this, just backed-out one of the too-long bolts a thread and called it good.
Now, the second problem is clearly visible...
this is known as the "Lance Armstrong" version of the halfshaft.
Posted: Sun Dec 12, 2021 1:58 pm
maddog2020 wrote: ↑Sun Dec 12, 2021 11:49 am
I've been told that that version's shaft is also much shorter.
Posted: Sun Jan 02, 2022 4:32 pm
by Scoper
When I got my 78 on a lift I saw grease sprayed all over the back part. The pattern suggested the CV joints. Turns out early cars have 2 gaskets per joint and someone had redone them with a later kit that had 1 gasket per joint! Messy job but never saw the insides of a CV joint!
Posted: Mon Jan 03, 2022 4:07 pm
by Scoper
When I got my 78 home, the turn signal only occasionally cancelled. A prior dufus had installed the ring 120 degrees off!
