By worf - Sat Dec 11, 2021 10:20 pm
#121753
But the clearance of the hub and the transaxle flange is such that an extra couple of MMs of length is sufficient to cause interference. The main problem here was two day different both lengths required and rather than 6 and 6 there was 5 and 7 and the odd long bolt was on the hub side.
Now that I think about it, I’ll bet the count is 7 and 5 on the other side. (But, that 928 isn’t here anymore.)
The Fat Man wrote: ↑Sat Dec 11, 2021 9:36 pm Was the 'too-long-bolts' CV joint at the transmission or wheel hub side?Wheel hub.
My 928 Inspection Guide
