Page 4 of 4
Re: 928 quick questions thread
Posted: Sun Dec 14, 2025 4:17 pm
Posted: Sun Dec 14, 2025 7:41 pm
by Fox_
Does this fit the bellcrank end of the pushrod that actuates the throttle body? I seem to remember something about that one not being cut for the retaining clip.
Posted: Sun Dec 14, 2025 8:02 pm
Fox_ wrote: ↑Sun Dec 14, 2025 7:41 pm
Not all of the ball cups have the hole through the neck to accept the retainer.
The cable from the linkage to the throttle body usually does not. At either end.
It does seem to vary year-to year with later years having fewer clips.
Posted: Tue Dec 23, 2025 3:09 pm
by h2pmr
anybody know if either of these are genuine 928 versions ?
and Happy Holidays to all
Posted: Sun Dec 28, 2025 7:57 pm
by Fox_
After sitting for some time my 928 had ABS issues. Would trigger the ABS pump while not moving.
I just pulled the ABS relay. When I cleaned the wheel speed sensors I found the male/sensor side plugs had deteriorated. The harness/female side seemed okay.
Is there a solution for this or do I just order new wheel speed sensors?
I'm ordering all the stuff I need to rebuild the AC system, need new main fan bearing, and while I have the dash out to inspect vacuum AC controls I plan on recovering it.
This car costs me $3000 minimum every time I touch it, it seems.
Posted: Tue Dec 30, 2025 5:17 pm
by jschiller
These are available which simulate (to a degree) the round connectors if originality is not important to you:
https://www.ebay.com/itm/305021891511
Posted: Sun Feb 08, 2026 10:53 am
by h2pmr
does this hand brake lever cover look like a factory leather version, or an aftermarket one ?
Posted: Thu Feb 12, 2026 9:34 am
by Fox_
Air filter straps. Alternative source? Mine are starting to look crispy.
I went to order some this morning and got sticker shock $450.
Posted: Thu Feb 12, 2026 1:58 pm
Not that I know of.
Posted: Thu Mar 05, 2026 3:32 pm
by h2pmr
small trim piece under the dash pod, the standard black one just has the part number, the blue one also has PP02 on it.
i guess thats an original colour code, anybody know what name of blue it is ?
Posted: Thu Mar 05, 2026 6:53 pm
Color code and color name will be in PET.
Posted: Fri Mar 06, 2026 3:22 pm
by h2pmr
thanks Dave, i had a look on PET and it could be marine blue or cobolt blue, but looking online my guess is marine blue as google AI says marine blue is a deep dark blue shade.
Posted: Fri Mar 06, 2026 3:46 pm
h2pmr wrote: ↑Fri Mar 06, 2026 3:22 pm
Interior cobalt blue is pretty bright.
Posted: Sat May 02, 2026 7:56 am
by h2pmr
is this a kempf belt tension tool ?
all the ones pictured online seem to have a black spring
Posted: Sat May 02, 2026 9:32 am
Yes, it's a Kempf tool.
Posted: Sat May 02, 2026 1:49 pm
by h2pmr
thanks Dave
Posted: Sun May 24, 2026 7:42 am
by h2pmr
anybody know what bulb fits in a 92863211101 ?
its just listed in PET in the dashboard section and not with the other interior lights
Posted: Sun May 24, 2026 8:55 am
h2pmr wrote: ↑Sun May 24, 2026 7:42 am
OTTOMH, without trudging to the shop to look, I think it's the same as the bulb for the interior lights. Easy to check.
Posted: Sun May 24, 2026 8:58 am
by jschiller
PET says 99963101890 Bulb M 12V, 3W.
Not so?
Posted: Sun May 24, 2026 1:33 pm
jschiller wrote: ↑Sun May 24, 2026 8:58 am
Not so?
Not so. '91+ is different from -90. And it is as I wrote: same as interior lights.
Posted: Sun May 24, 2026 1:37 pm
Oh... and Phil? Are you hungover dude? That was not Advanced PET Sluthing
Posted: Mon May 25, 2026 2:21 pm
by h2pmr
thanks Dave
i just saw it on the PET listing pictured, i have never actually seen one before, i did see that on the interior light page but did not check what its part number was as it looked nothing like its pictured below
+ its hot and sunny at the moment over here so beer even warmer than usual
Posted: Mon May 25, 2026 4:09 pm
Posted: Sun Jun 07, 2026 7:42 pm
by Fox_
I've noticed a new transmission leak, it's on the passenger side near the reservoir. It doesn't look like the pan gasket as it's wet above it as well.
Transmission last serviced in ~2021, last work done was changing the vacuum modulator ~6 months ago. That side is clean.
It wasn't leaking, drove the car a couple thousand miles, now it's leaking. I'd like to get it addressed before I take it off the lift bars tomorrow. Anything common?
Posted: Sun Jun 07, 2026 8:17 pm
Fox_ wrote: ↑Sun Jun 07, 2026 7:42 pm
Cap loose?
Is the cap's seal missing? Or wounded?
Posted: Tue Jun 09, 2026 5:00 pm
by Fox_
I loosened the cap and fluid started flowing out, tightened it back.
90% sure it's the cap now.
That's a project for next time around.
Posted: Tue Jun 09, 2026 6:31 pm
Fox_ wrote: ↑Tue Jun 09, 2026 5:00 pm
It's supposed to do that. When the automatic isn't turning (pump's not pumping) the fluid level is above the reservoir. Thus the cap must be tight and its seal must be in one good piece or fluid will leak when the 928 is stopped. Or when you loosen the cap.
Posted: Sat Jun 13, 2026 3:20 pm
by h2pmr
my basic PET lists these 2 HAVAC control units as for Canada market only
anybody know what the difference it makes in Canada ?
Posted: Sat Jun 13, 2026 3:53 pm
I can conceive of no politically correct answer.
Posted: Sat Jun 13, 2026 4:02 pm
by h2pmr
Roger just told me its that Canada use centigrade and not the old fashioned fahrenheit......
Posted: Sun Jun 28, 2026 5:39 am
by h2pmr
anybody fitted an early version bottom pulley 92810213911 onto a GTS which should have the 92810213912 pulley ?
is there that much difference in alternator pulley size that you would need to fit the smaller belt ?
Posted: Sun Jun 28, 2026 10:37 am
h2pmr wrote: ↑Sun Jun 28, 2026 5:39 am
I have not and have no idea.
IIRC the larger pulley's purpose is to spin the alternator faster on auto-box 928s. But, the data in the parts pages augurs poorly.
Posted: Sun Jun 28, 2026 3:21 pm
by h2pmr
worf wrote:h2pmr wrote: ↑Sun Jun 28, 2026 5:39 am
thanks Dave, i have listed an 11 on ebay and i think the 12 is NLA so someone is bound to ask me the question
Posted: Tue Jul 14, 2026 4:35 pm
by h2pmr
what is a good, all original wiring at the rear, no damage, fuse panel worth at the moment ?
its from a 90 92861010519 and i just googled the price of a new one
Posted: Tue Jul 14, 2026 5:53 pm
h2pmr wrote: ↑Tue Jul 14, 2026 4:35 pm
dunno.
iirc the new ones aren't wired!!
Posted: Wed Jul 15, 2026 2:50 pm
by h2pmr
worf wrote:h2pmr wrote: ↑Tue Jul 14, 2026 4:35 pm
dunno.
he said £250, i said £300 and he bought it for £300.
an amazing rats nest of wire going on on these old fuse panels, i showed it to an apprentice mechanic at work today, did not want to know how to use a multimeter to test it all, just took a picture on his phone to send to his mates...
