Does this fit the bellcrank end of the pushrod that actuates the throttle body? I seem to remember something about that one not being cut for the retaining clip.
Fox_ wrote: Sun Dec 14, 2025 7:41 pm Does this fit the bellcrank end of the pushrod that actuates the throttle body? I seem to remember something about that one not being cut for the retaining clip.
Not all of the ball cups have the hole through the neck to accept the retainer.
The cable from the linkage to the throttle body usually does not. At either end.
It does seem to vary year-to year with later years having fewer clips.
anybody know if either of these are genuine 928 versions ?
and Happy Holidays to all
After sitting for some time my 928 had ABS issues. Would trigger the ABS pump while not moving.
I just pulled the ABS relay. When I cleaned the wheel speed sensors I found the male/sensor side plugs had deteriorated. The harness/female side seemed okay.
Is there a solution for this or do I just order new wheel speed sensors?
I'm ordering all the stuff I need to rebuild the AC system, need new main fan bearing, and while I have the dash out to inspect vacuum AC controls I plan on recovering it.
This car costs me $3000 minimum every time I touch it, it seems.
By jschiller
#327786
These are available which simulate (to a degree) the round connectors if originality is not important to you:
https://www.ebay.com/itm/305021891511
does this hand brake lever cover look like a factory leather version, or an aftermarket one ?
Air filter straps. Alternative source? Mine are starting to look crispy.
I went to order some this morning and got sticker shock $450.
Not that I know of.
small trim piece under the dash pod, the standard black one just has the part number, the blue one also has PP02 on it.
i guess thats an original colour code, anybody know what name of blue it is ?
Color code and color name will be in PET.
thanks Dave, i had a look on PET and it could be marine blue or cobolt blue, but looking online my guess is marine blue as google AI says marine blue is a deep dark blue shade.
h2pmr wrote: Fri Mar 06, 2026 3:22 pm thanks Dave, i had a look on PET and it could be marine blue or cobolt blue, but looking online my guess is marine blue as google AI says marine blue is a deep dark blue shade.
Interior cobalt blue is pretty bright.
is this a kempf belt tension tool ?
all the ones pictured online seem to have a black spring
Yes, it's a Kempf tool.
thanks Dave :beerchug:
anybody know what bulb fits in a 92863211101 ?
its just listed in PET in the dashboard section and not with the other interior lights
h2pmr wrote: Sun May 24, 2026 7:42 am anybody know what bulb fits in a 92863211101 ?
OTTOMH, without trudging to the shop to look, I think it's the same as the bulb for the interior lights. Easy to check.
By jschiller
#342840
PET says 99963101890 Bulb M 12V, 3W.
Not so?
jschiller wrote: Sun May 24, 2026 8:58 am PET says 99963101890 Bulb M 12V, 3W.
Not so?
Not so. '91+ is different from -90. And it is as I wrote: same as interior lights.
Oh... and Phil? Are you hungover dude? That was not Advanced PET Sluthing :silenced:
thanks Dave
i just saw it on the PET listing pictured, i have never actually seen one before, i did see that on the interior light page but did not check what its part number was as it looked nothing like its pictured below
+ its hot and sunny at the moment over here so beer even warmer than usual :beerchug:
h2pmr wrote: Mon May 25, 2026 2:21 pm + its hot and sunny at the moment over here so beer even warmer than usual :beerchug:
Ah. Yes, I can see how, on the one or two days a year the Sun comes out over there, that the effect might be stunning :lol2: :drunk: :kickbutt:
Skyhawk172 liked this
I've noticed a new transmission leak, it's on the passenger side near the reservoir. It doesn't look like the pan gasket as it's wet above it as well.
Transmission last serviced in ~2021, last work done was changing the vacuum modulator ~6 months ago. That side is clean.
It wasn't leaking, drove the car a couple thousand miles, now it's leaking. I'd like to get it addressed before I take it off the lift bars tomorrow. Anything common?
Fox_ wrote: Sun Jun 07, 2026 7:42 pm I've noticed a new transmission leak, it's on the passenger side near the reservoir. It doesn't look like the pan gasket as it's wet above it as well.
Cap loose?
Is the cap's seal missing? Or wounded?
I loosened the cap and fluid started flowing out, tightened it back.
90% sure it's the cap now.
That's a project for next time around.
Fox_ wrote: Tue Jun 09, 2026 5:00 pm I loosened the cap and fluid started flowing out, tightened it back.
It's supposed to do that. When the automatic isn't turning (pump's not pumping) the fluid level is above the reservoir. Thus the cap must be tight and its seal must be in one good piece or fluid will leak when the 928 is stopped. Or when you loosen the cap.
hernanca liked this
my basic PET lists these 2 HAVAC control units as for Canada market only
anybody know what the difference it makes in Canada ?
I can conceive of no politically correct answer.
Roger just told me its that Canada use centigrade and not the old fashioned fahrenheit......
anybody fitted an early version bottom pulley 92810213911 onto a GTS which should have the 92810213912 pulley ?
is there that much difference in alternator pulley size that you would need to fit the smaller belt ?
h2pmr wrote: Sun Jun 28, 2026 5:39 am anybody fitted an early version bottom pulley 92810213911 onto a GTS which should have the 92810213912 pulley ?
I have not and have no idea.
IIRC the larger pulley's purpose is to spin the alternator faster on auto-box 928s. But, the data in the parts pages augurs poorly.
thanks Dave, i have listed an 11 on ebay and i think the 12 is NLA so someone is bound to ask me the question :beerchug:
what is a good, all original wiring at the rear, no damage, fuse panel worth at the moment ?
its from a 90 92861010519 and i just googled the price of a new one :eek:
h2pmr wrote: Tue Jul 14, 2026 4:35 pm what is a good, all original wiring at the rear, no damage, fuse panel worth at the moment ?
dunno.
iirc the new ones aren't wired!!
dunno.
he said £250, i said £300 and he bought it for £300.
an amazing rats nest of wire going on on these old fuse panels, i showed it to an apprentice mechanic at work today, did not want to know how to use a multimeter to test it all, just took a picture on his phone to send to his mates... :surrender:
