By captainOCD
#83941
-full set of spare belts
-spare fuel pump
-fire extinguisher
#83944
Allen sockets and keys.
Fuses/Relays/Jumpers
Silicone tape.
LH (EZK's usually don't fail)
2 gal distilled H2O
Jug of oil (5qt)
Breaker bar and 27mm socket
Small, low profile jack.
Impact gun
Bourbon.
By captainOCD
#83959
I like the bourbon
#84002
Spare fuses
Sandpaper
By UKKid35
#84168
Scoper liked this
#84291
By Redgt
#84399
#84447
linderpat liked this
#84836
I also carry one of these
#85050
Great thread!
My kit is a work in progress:
1/4" Stahlwille socket set
set of wrenches
long standard screwdriver
They sure do look great, resale has been poor on t[…]
I just paid for a 2018 panamera 4s e-hybrid in gt […]
