By wwilliams888
#7977
Nice upgrades! The only problem i have is that my iPad only displays the mobile version, i.e, the left pane with the avatars and other info is not visible. Is their a toggle so that I can view the full version on the iPad? Thanks
wwilliams888 wrote: Sun Aug 16, 2020 10:23 am Nice upgrades! The only problem i have is that my iPad only displays the mobile version, i.e, the left pane with the avatars and other info is not visible. Is their a toggle so that I can view the full version on the iPad? Thanks
Yeah I'm noticing now that the mobile version doesn't have quite as many functions. Let me check with the developer and see how we can get around that.
By Patrick
#7981
On your iPad:
Settings-> Safari-> (near the bottom)Request Desktop Site-> All Websites ->On
By wwilliams888
#8010
Unfortunately, that is the setting it’s already on. I tried toggling it off, rebooting and toggling it on, but no change on iPad
By Cuda911
#8062
Same issue on android phone, cant see avatars, etc.
One suggestion, can you make the text that is gray black instead? Gray is harder to read.
Cuda911 wrote: Sun Aug 16, 2020 1:27 pm Same issue on android phone, cant see avatars, etc.
Yes I think the mobile version turns off a little too much for the sake of simplicity. Speaking with the developer about that.
I'll look into changing that text color right after a late lunch :)
By Cuda911
#8096
Is there a setting so I can see how many views/replies in a thread? The layout view on my phone is pretty minimalistic.
By Patrick
#8101
wwilliams888 wrote: Sun Aug 16, 2020 11:42 am Unfortunately, that is the setting it’s already on. I tried toggling it off, rebooting and toggling it on, but no change on iPad
Weird. Both of my iPads are set that way and they’ve never once loaded the mobile version. (They used to load the mobile version of the other site from time to time before I discovered that setting).
By Patrick
#8135
wwilliams888 wrote: Sun Aug 16, 2020 3:12 pm Software version issue? I’m running iPadOS 13.6.1.
Yep. Latest.
