By Tony - Tue Mar 23, 2021 12:54 pm
#68393
I just did this last year but the he!! If i can find my notes on it...i just replaced the front bushing on the weissach arm.(#12) Last piece of rubber on the underside.
Need the values for these hi-lited. The wsm has them i know but trying to figure out what they are describing in their descriptions gives me questions.
# 41..42. .....3 bolts on the mounting of the front of the weisach arm to the under body....33ft lbs (light alloy casting for lower control arm to body)
#25....The link pin nuts....pretty sure those are 103ft lbs. (wheel carrier to lower suspension link)..but see refernce to 80ft lbs also
#8...On the blade of the weissach arm.... Camber ...146 ft lbs
#16...On the front of the weissach arm.......Track....88 ft lbs
These look familiar......????
