By Tony
#64540
Sealing washers on front brakes
87s4 with big reds
ive seen and heard two things.
#1. 1 sealing ring between the banjo bolt and the fitting as illustrated
#2. 2 sealing rings...1 between the banjo bolt and the fitting.....and....the fitting and the caliper block.
the WSM shows 1 sealing ring in the image yet describes 2 needed in the text?
Is that one on each side L and R....or ...2 on each side for total of 4.
part #14
I've always found, and used, 2 on each side of each banjo bolt.
PET wrong AFAIK.
By Tony
#64559
Yup...two.
One set was stuck and well flattened to the fitting...
Move along...nothing to see here.... :surrender:
While im at it...
What is the tq spec on that banjo bolt. I know it is treaded into the aluminum caliper.
By Tony
#64560
Oh...and a tip. Dont let it ge too close to the hot part of the flame on your torch. It happens very quickly. :silenced: :roflmao:
By Tony
#64564
...dunno...original...
Was going to hit up Rog for a set steel braided lines. Any thoughts on those.....
Tony wrote: Fri Mar 05, 2021 7:21 pm What is the tq spec on that banjo bolt. I know it is treaded into the aluminum caliper.
Front: 16.5 N-m
Rear: 14.0 N-m
By Tony
#64727
Thanks guys. Just ordered a set of SS lines from Rog. 34yrs old would probably be a good idea...its all open now anyway. Just hope the lines break free without any drama.
SeanR liked this
