By worf - Mon Feb 22, 2021 8:22 pm
#61635
So... I'm not going to stop you from that hill, but you don't have to die on it.
As soon as the snow melts enough for me to get to my storage I'm sending Fikse/Kodiak my eff'd up wheel and between me, Jeannie, Fikse, Kodiak, etc., we are going to damn well reclaim the "lost art" of the 68.5mm offsets.
maddog2020 wrote: ↑Mon Feb 22, 2021 6:43 pm if anyone is going to die on the Fikse hill it will be me. I had my rear quarters cut off and then put GTS quarters and had them widened even more so I could get 335's on the back.You know you can call Augment and they will make you a wheel in - literally - any offset you want right?
Knowing what I know now, I probably would have had them do the fronts wider as well. The shorter spindle & hubs will work for me (as well as shorter rotor hats)To each his own, but I'd rather get custom front fenders made than mess around with "the negative spacer" thing.
My 928 Inspection Guide
