By maddog2020 - Wed Dec 30, 2020 4:50 pm
#45978
I've been collecting info for a while on various 928 stroker engines and wanted to post it here so people could start to see data on them.
I'd like to keep this thread technical, data driven in nature. I'm familiar with the engines listed below and will add more data as I scour several hard drives for it.
this is from various forums & in no particular order:
Mike S. 7 liter (640 hp @ 7500RPM 501 torque peak torque between 5-6K) Designed for track use
109mm bore, wet steel sleeves, nikasiled
Custom forged pistons for 10.5:1 compression
94mm custom Moldex crank, LS7 titanium rods
Simard main and head studs
Block halves are 'shuffle pinned'
Dry sumped
ATI damper, Simard lightweight flywheel for 7.25 dual disc racing clutches, hydraulic throwout bearing
Heads are CNC ported with 40mm intake valves and stock 33mm exhaust
Simard 56mm ITB's
Simard gun drilled billet cams with 12.7 lift intake and exhaust
Motec M48 Pro ECU sequential injection & ignition
Pump gas 91 Octane
Louie O. 6.5 liter (603 HP & 6400RPM 531 peak torque between 4300 to 5500) Designed for street use
104mm bore
944S2 pistons 10.2:1 compression.
95.25mm scat crank
TWM 50mm ITB's with Ott adapters
39mm (968)intake valves and stock 33mm exhaust
Devek B1 cams - intake .435 lift 230 dur, exhaust .404 lift 228 dur
Stock lifters
ECU: DTA P8 Pro
wasted spark coil near plug
Pump gas 91 octane with Alcohol injection @ full throttle
Don H. 6.4 liter (440hp & 478 torque)designed for track use
104mm bore
Modified 968 pistons
95.25mm scat crank
TWM 52mm ITB's with Ott adapters
968 Intake valves with stock exhaust valves
Stock GT cams
Stock lifters
Stock ECU & ignition
John V 6.4 liter (550hp)designed for track use
104mm bore
944s2 pistons
Oliver steel rods
95.25mm scat crank
custom webcams cams
Stock lifters
DTA Pro 8 ecu
Anonomous owner 6.57 (602HP @ 6700 520 torque engine dyno) liter designed for track use
108.9mm bore
Carrillo light weight Greg B. designed rods
93.98mm crank
High Rise intake
no piston, cam or lifter info
Electromotive ECU
110 Octane race gas
Mine
6.5 liter Designed for street use
86 block bored to 104mm, nikasil plating
JE pistons for 11.5:1 compression
95.25mm custom scat crank
Oliver 5.850 titanium rods
TWM 50mm ITB's with modified Ott adapters
45x50mm oval cylinder head intake ports are CNC ported to 50mm round, with 39mm (968)intake valves and stock 33mm exhaust
Simard billet gun drilled cams intake - .450 lift 226 dur, exhaust .420 lift 220 dur
Lightweight VW black nitrided lifters
Porsche main studs, Simard Head studs
ATI damper, AASCO flywheel, Tilton clutch , Tilton hydraulic T/O
Link Thunder ECU sequential injection and ignition
Injector Dynamics ID725 injectors
VW/Audi coil on plug
Pump gas 93 octane, E85
Dry sumped
Simard 56mm ITB's
Pump gas 91 Octane
104mm bore
95.25mm scat crank
Stock lifters
ECU: DTA P8 Pro
104mm bore
95.25mm scat crank
Stock GT cams
Stock lifters
104mm bore
944s2 pistons
Oliver steel rods
95.25mm scat crank
custom webcams cams
Stock lifters
DTA Pro 8 ecu
108.9mm bore
93.98mm crank
High Rise intake
Electromotive ECU
110 Octane race gas
Mine
