By shadetree - Mon May 11, 2026 4:50 pm
#341730
Hello, this is for my 1983 US spec 928S. My a/c system has not been converted so it remains R12. It has historically worked in the few years I've had the car but gradually gotten less cold when using. The compressor clutch quit engaging so I tested the electrical circuit first. I was getting 12v on both prongs of the freeze switch and 12V on one of the leads to the low pressure switch attached to the dryer. The clutch engaged when I jumped the two leads at the low pressure switch.
Next I put my manifold gauges on to check pressures and have 0 pressure on both high and low sides. No hiss at all at the connections so it's empty. I don't see any obvious oil residue evidencing a leak on the expansion valve or any of the connections I can see from the top side. I'll get it up on jacks in the next couple of days and look at the compressor for any obvious signs of leak residue.
I'm looking for any thoughts on best way to find the leaks. I've read about using nitrogen, or simply adding some refrigerant along with dye. Do I need to add oil before testing? Any input is appreciated. Thank you.
1983 928S 5 speed
