By Crumpler - Thu Nov 12, 2020 9:28 pm
#33848
It’s predictable with this car. Any major projects and she is a PITA to get running again, WTF.
This round includes top end work so injectors and rails were off. Ran well two weeks ago “when parked”, infact, I drove the f’er home from the track.
Cranks. But no start.
So far:
Fully charged battery. 12.47 v at CE
FP fuse good.
All relevant relays switched out for good.
All top end connections checked.
Battery connections and grounds are solid.
Jumped FP relay, FP runs. 66 psi on rail, holds at 52 after.
Spark tested positive both banks with indicator light.
Pulled LH connection, cleaned and sprayed with Deoxit.
I was going to put noid lights on next to check injector pulse.
Last time I did this I had a LH loaner from Roger. Switching them did nothing. With mine back on it started randomly again at WOT. That was roughly three months ago the last time it was up on jacks for an extended period. In that go round I had replaced MAF as well.
Thoughts please ;)
So far:
FP fuse good.
Thoughts please ;)
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
