By Zirconocene - Tue Jan 27, 2026 5:06 pm
#330724
Here's a convoluted question, driven by all the information I've been able to find and (attempt to) synthesize.
As a general concept, I understand that the spring rate for the front suspension is not driven solely by the spring itself; the rubber bushings that are all part of the front suspension (lower control arms, for example) play a role in an effective spring rate. I don't know what those components contribute to effective spring rate as discussions over on RL became heated quickly in certain threads where these kinds of things were starting to be discussed (and, to be fair, there is some trade secret stuff to be cognizant of in the measurement of those things). I understand that Carl measured the stock Porsche, Weltmeister, and Bilstein (?) spring rates and found pretty different numbers between stock and aftermarket.
It also sounds like, per Greg, that moving to Bilstein shocks obviated certain suspension components, the upper spring perch (or concave washer, or spring bearing, whatever; the thing that gradually squishes that Worf investigated on this site a while ago) in particular. Other experienced folks (like Sterling, based on his offering in his store), seem to prefer the Konis, which my reading indicates rely on the upper spring perch to make everything feel good.
Now to my question: Does the stock upper spring perch play a role in the effective spring rate on a stock car? It's a big chunk of rubber so I understand the role in NVH but it's also a big chunk of rubber, so there should be some non-negligible spring rate. Has that been measured?
What I'd really like to get to is a rebuildable option for those parts but I'm trying to, at least, work out the concepts involved, in my head.
If you've read this far, thanks, I'd love to hear your thoughts on things.
Cheers
Cheers
