Ok. I understand the confusion.
Crumpler wrote: ↑Thu Jan 22, 2026 6:28 pm
So my first thought was that the cam seal was basically like the plug, where I could extract it with the proper puller, and then replace it with the proper driver. With cover on and bridge intact, in and out. This may have been fantasy on my part.
You can replace the cam seal with the front bridge in place.
That's part #9 in the diagram (WM 15-120?) you posted.
I found a thread on RL that was all over the place.
Screw rennlist. So many people posting 'solutions' that it's too hard to find the (correct) signal in the noise.
WSM (15-128) gets confusing to me. There’s an 87 onward for seal installation, it shows covers (plugs) going in after bridge is torqued but no mention of cam seal per se.
First look at WM 15-128 step 19. This shows the installation of the cam (lip) seal and is the same for all 32v heads. The cam belt gear is attached to the the nose of the exhaust cam. The bearing bridge has high-pressure oil journals. The lip seal is what keeps the oil from squirting out.
I highly recommend looking at 15-119 tools #2 and #3. #3 slides over the nose of the cam. You oil the outside of the tool and slip the cam seal onto it and slide the seal forward. #3 thus prevents the nose of the cam from damaging the lip of the seal (which if damaged means that it WILL leak and you get to do this all over) and uniformly expands the lip seals spring. #2 is then used to drive the seal in.
I have a picture of this which I will hopefully not forget to attach to this post.
On page WM 15-128a, step #1 shows cam journal plugs for the *rear* cam bearing surfaces. These are needed for '87+ because the (shorter) '87+ cams do not use the rear cam bearing surfaces. That 'hole' is just open. Nothing fills it except the plugs shown.
Your S3's cams are 'long' and DO use the rear bearing surfaces. But, because the rear end of the cam doesn't need to protrude out of the head to accept a gear it doesn't need a lip seal like it does in the front.
On the same page, step #2, shows (with tool #2) driving in the 'cam hole plugs' that are used in the three holes per head that do not pass a cam nose through.
The plugs for the '87 are needed because otherwise all the pressurized oil for the cam bearings would just squirt out of those journals. Thus, they seal the journals; they actually have a little metal pin that does the sealing. In later years the rubber part is deleted and it's just a long pin (short story, long story out of context for S3.)
Clear(er)?
My 928 Inspection Guide
