By JBT3 - Fri Jan 02, 2026 4:44 pm
#328054
Hi Guys
I'm in the beginning stages of my winter project and wanted to check a few things. The project is a R&R on the complete suspension, torque tube, wheel bearings, tranny reseal, X-pipe, and Hans shifter. I'm planning on dropping everything from the clutch back to R&R, clean, soda blast and powder coat where needed.
I already have the RWBs out. (the grease had dried out and they were disgusting looking. Smelled like gear oil.) I'm not putting the new bearings in yet, because the hub carrier and pretty much everything attached to it needs some love.
Wanted to check order of operations with you guys given all the above. Realized today I've already eliminated an easy way to get to the rear pinch bolt on the torque tube by removing the hubs. But i think I can just put it in gear and spin the engine to get the rear bolt to line up with the access port.
Order of Operation for removal (major steps):
1. Remove exhaust (done)
2. Remove rear axles (done)
3. Remove clutch (WSM 30-6b to 6c)
4. Remove shift lever
5. Remove tranny (WSM 34-5 to 34-7) and torque tube (WSM 39-61) together
Questions
1. Is my order of operation, correct?
2. Are there any steps I should take ahead of time before moving to the next major disassembly step to make life easier?
3. Per Q2, seems like I should remove the rear pinch bolt now before removing clutch, correct?
Questions
