By maddog2020 - Wed Dec 24, 2025 10:47 pm
#327351
(PRICE DROP)
928 Innovations Aero strut bars for the 87 to 91 S4 & GT's are ready to order. This is going to be a pre order buy only. Bars will be solid bare 7075 T6 Aluminum. Unfinished.
Original price was $700 ONLY IF WE COULD GET AN ORDER OF 10.
(PRICE DROP INFO)
We're able to get in on a bulk purchase of 7075 T6 so I'm dropping the price on the pre ordered S4/GT strut bars to 549 with a deposit of $275. 6 out of 10 are pre sold. I decided to buy 2 for stock, so that leaves 2 open for purchase.
Original Deposit was $350 and was due by Jan 2nd. I've extended the pre buy until January 15th. Bars will be available to ship 1st week in March.
These are specifically for 87 -91 S4 & GT models only, with notches for the oil filler cap as well as a longer notch in the rear side for the intake.
We do have a design for ITB engines that should fit the earlier 78-84 models but I need a car to test fit in the DFW area, however this version is curved. We are working on a version specifically for the 78-84 versions that will have a notch on the rear side specifically to clear the oil filler housing.
Factory strut bars are hollow thin wall 5052 H32 Aluminum. This strut bar is solid 7075 T6 aluminum which is much stronger than the 5052 factory bar. They also look much better and fit the styling of the 928 body lines.
5052-H32:
Ultimate Tensile Strength: ~33,000 psi (228 MPa)
Yield Strength: ~28,000 psi (193 MPa)
7075-T6:
Ultimate Tensile Strength: ~83,000 psi (572 MPa)
Yield Strength: ~73,000 psi (503 MPa)
Keep in mind the factory bar is hollow thin wall, and these are solid.
(PRICE DROP INFO)
5052-H32:
7075-T6:
