By N_Jay - Sat Sep 06, 2025 3:05 pm
N_Jay wrote: ↑Sat Sep 06, 2025 3:05 pm My nieces boyfriend/partner managed to let the timing belt shread on his 2012 mini.Wow crazy timing as I was about to post something about how much fun my daughter's 2015 Mini Cooper S is to drive.
Supposedly the car is otherwise is in great shape.
Anyone have any experience as to how to not lose all the value.
@XR4Tim What would a used Mini engine insaltall typically cost?
yellowducman wrote: ↑Mon Sep 08, 2025 9:37 am Car-part.com. You got a lift. I put a clutch in my 05 and it wasn't that bad. I can't imagine a engine swap would be that much worse.Videos show removing most of the front of the car, with notes about some typically difficult items.
N_Jay wrote: ↑Mon Sep 08, 2025 12:59 pmMini model years and chassis generations are a mess when you're looking for parts.yellowducman wrote: ↑Mon Sep 08, 2025 9:37 am Car-part.com. You got a lift. I put a clutch in my 05 and it wasn't that bad. I can't imagine a engine swap would be that much worse.Videos show removing most of the front of the car, with notes about some typically difficult items.
Looked at car-part and Ebay, but 2012 sees to be a split model year, so i need to do more research after I get my hands on thr car.
The owner is not as technical as he thinks he is.
XR4Tim wrote: ↑Fri Sep 12, 2025 11:07 am I don't have a labor guide handy, but I would imagine replacing the engine with a complete used unit would be in the 15 hour range. My guess is that the whole assembly would drop out the bottom with the subframe. I did a clutch on a friend's 2002 Cooper S once, and it was a challenge (without a transmission jack, and without dropping the subframe).Thanks
XR4Tim wrote: ↑Fri Sep 12, 2025 11:07 am I don't have a labor guide handy, but I would imagine replacing the engine with a complete used unit would be in the 15 hour range. My guess is that the whole assembly would drop out the bottom with the subframe. I did a clutch on a friend's 2002 Cooper S once, and it was a challenge (without a transmission jack, and without dropping the subframe).When I did the clutch on my 05, I dropped the subframe. I also did bushings power steering hoses, and other things. It became a slippery slope. Of course anytime I had to work on that thing you had to put it into service mode which included pulling the nose forward a few inches.
