when Porsche found they had oil usage issues with the GTS and they fitted new engines, did the engines come with an engine number stamped into the block ?
or did they used to just put a block with pistons and crank etc in and would that come with an engine number on the block ?
h2pmr wrote: Fri Sep 05, 2025 1:21 pm when Porsche found they had oil usage issues with the GTS and they fitted new engines, did the engines come with an engine number stamped into the block ?
IIRC the block stamp was different for warranty-replaced engines. I don't recall specifics. But, on TOS, there's a least one thread discussing it.
If you find the answer on TOS, post it here. :beerchug:
worf wrote: Fri Sep 05, 2025 3:07 pm
thanks Dave looked on TOS, via google search as TOS has to have the worst search engine ever.
reading the posts it looks like complete engines usually but not always, got a stamping of some kind.
but a short motor / block got nothing stamped on it.
i have not actually seen the block, but hopefully will get a picture of it just to check its not just been filed off.
if i get any warranty history from it to confirm anything i will post on here.
My understanding is that warranty replacements were complete engines. Not short or long blocks.
