By Addlight - Mon May 19, 2025 3:02 pm
#308313
I noticed that the coolant pressure switch on my 86.5 (928 641 513 00) is starting to leak. I did a little research and found that a replacement is silly expensive (~$170) for a what it is. However, I also saw a few threads where people said to just remove the switch because it has little to no use.
Is this correct? Is the switch's job to detect when the reservoir has been opened and the system depressurized, which then turns a low coolant light off under the assumption that since the system is depressurized that someone opened the reservoir and added coolant? That seems byzantine even by German engineering standards.
If this is true, two questions: 1) Is it better to just replace tat entire hose or to splice in a coupler where the switch was? 2) What to do with the switch's electrical connector? Tape it off and tuck it out of the way?
Thanks,
Matt
Thanks,
Matt
86.5 black/black, 5-speed, no rub strips, always undergoing some experiment
