#302937
Are those Cam Seal Retainers anodized?
What else is in the product pipeline boss?
Curious.
I want an oil filler neck.
Want big -AN hookups on that filler neck.
I don’t care anymore if fill port is stock cap size.
lots of stuff in the pipeline. parts and custom tools as well. the goal is to release 32 parts this year in small batches of 4-5 at a time & sold thru Roger. The rotor hats will make some nice choices out there for the 928. Stock is pictured above and will allow you to mount a 355mm front rotor on an S4 or later front spindle so for those with 86.5 track cars or earlier track cars with 86.5 or later front spindles you could put some massive brakes on. I also have a different rotor hat available for those that decide to go with the "negative spacer trick" and go with 944 hubs to provide more wheel and offset choices.
hernanca liked this
By The Fat Man
#303175
How long until these parts hit your storefront?
I am in for a set of the anodized cam seal retainers.
Seth K. Pyle
