hi
was going to finish off a thread, but would take more than a day as need to take pictures as i went.
but saving a draft does not save the pictures inserted.
any reason why ?
Let me run through some test scenarios as I've never tried that one.
I know the photo upload feature is something I added as an additional feature so that might have something to do with it.
I'll check it out later today and let you know.
h2pmr wrote: Sun Mar 23, 2025 8:20 am hi
any reason why ?
Did some research and found that this is a default "feature" of the platform we're using.
Now there have been some mods published to address this but it doesn't seem to be perfect. So if this something you think you'll be doing often I'll look into how I can implement that modification but I'm a bit hesitant to modify the code because of the issues we had during the last update.
Let me know your thoughts and we'll figure out next steps.
Thanks!
fpena944 wrote: Tue Mar 25, 2025 8:48 pm
any reason why ?
Thanks!
hi
many thanks for looking into it for me
no, its not something i would use often, i will just make a few posts as i go instead of doing one large post.
h2pmr wrote: Wed Mar 26, 2025 2:56 am
any reason why ?
Thanks!
hi
Appreciate the flexibility!
Let me know if anything else comes up.
