By hans14914 - Thu Jul 25, 2024 2:43 pm
#274069
Hey all,
I have been playing around with the some of the Musway products as a potential replacement for the factory 4 and 6-channel amplifier.
The Musway D8 fits well in the original location, and I have made brackets to fit this model into the later cars. Two different brackets are needed for the 10 and 8-speaker cars respectively. The brackets change in 89 for the 10-speaker system, and I have tested it on an 89 and 93. The brackets for the 88 and earlier cars have been tested on an 88 and 87 (It should fit all the 4-channel BQA80/BQB80 amplifiers).
The D8 is interesting for several reasons besides that it fits well with a custom bracket:
So, what does this mean for us 928 guys? You can keep your factory stock headunit for aesthetics and the AM/FM tuner, but stream music directly from your phone to the amp. You can even have a deadhead unit or no headunit and still have full control of the amp from the wired remote.
I have the brackets designed and a mount to install the remote in the ashtray insert. What I need is a wider testing audience to give some feedback on how the amp does in their environment, their experience is with the DSP software, integration into their headunit.... etc
I have applied and am now a Musway dealer, so can get hardware to those interested in helping test at a discount and provide the bracket and/or ashtray insert for the remote.
Shoot me a note if you are interested.
After getting several of these out there and validated, (pending good results) there will be amplifier upgrade kits with plug-in harnesses and brackets available with DSP configuration files for the factory speaker locations and levels.
- 8 channels of bridgeable and 2-ohm stable amplification (8x65w@4ohm) (4x360w@4ohm) - read you can power a factory 10-channel system plus a sub with 6x65w + 1x360w
Native bluetooth input - keep your factory headunit and stream hi-res audio directly to the amp
DSP - full featured DSP to do crossover, channel mixing, time alignment in the amp
Remote display - an optional wired remote unit with OLED display and rotary encoder-based interface allows easy selection of volume, input, sub level
