By maddog2020 - Sun Jun 23, 2024 9:54 pm
potdog wrote: ↑Mon Jun 24, 2024 11:52 am That's correct just like 928 Motorsports made them , but if you have a working low level sender no problem, that was a prototype .going to fit sight level tubeA sight-level tube is a must have.![]()
worf wrote: ↑Mon Jun 24, 2024 12:37 pmI meant to write that “ I will never fit an opaque expansion tank unless it has a sight level tube.”potdog wrote: ↑Mon Jun 24, 2024 11:52 am That's correct just like 928 Motorsports made them , but if you have a working low level sender no problem, that was a prototype .going to fit sight level tube…![]()
I will never fit an opaque expansion tank.
potdog wrote: ↑Mon Jun 24, 2024 12:55 pm Well blow me down just admit that you have a problem with me , yes it's me who made the oil neck baffle with louvers on top so that any one who did not have the Porsche plastic one , have you bought a Stainless Steel "Y" for the charcoal canister from Roger they are made by me . As for the opaque shite many vehicles have opaque header tanks so blow me down again "check water level regularly"Dude, I made the stainless Y-connectors 25 years ago. Sold a couple hundred of them. It became not worth my time and I posted the CAD drawing.
Crumpler wrote: ↑Wed Jun 26, 2024 9:34 am Interesting Jaguar worm hole this week for me.Dude!
Intermittent low coolant warning, but coolant not low.
The sensor uses a float, and of course, the float is attached to the fill tank not the sensor. Which requires replacing tank. That’s cool.
And yes Worf, I can see through the tank![]()
maddog2020 wrote: ↑Fri Jul 19, 2024 11:07 am diameter? thread pitch?I measure 36mm OD x 3.0mm pitch, original reservoir pulled from service many years (decades?) ago because color, not leaks.
Andrew S wrote: ↑Fri Aug 02, 2024 2:17 pmI haven’t been able to get back to that project yet. “Fix my A/C season” arrived with a vengeance.worf wrote:I will be testing a new one within a week or three.Worf, how is your new tank holding up so far? My replacement from 2019 has started to leak at the neck joint.
