By bigs
#2474
Every now and then, when I create a post and hit "submit," it fails to actually post. This seems to happen when someone else posts in the same thread at virtually the same time. It's as if the software can't handle simultaneous posts and therefore discards one. Anyone else have this issue?
It’s a feature. Your post is not posted before you review what others posyed between the time you started to write and post.
#2569
I was wondering about that also, especially the first day. I would click submit and then it would go to the preview and I'd have to click submit again.
Yes I've had the same happen and as described it's to update you on the latest post. I usually ignore and just proceed to submit.
I like the feature even if it’s a bit surprising.
