David993S wrote: ↑Fri Dec 15, 2023 7:00 am
UPDATE
I'm either quite unlucky, or very lucky, depending on your perspective. Actually.......probably both.
I get a call from the dealer where I bought the Aston yesterday afternoon. They were going to take care of a few small items the car needed before I went back to get it. They tell me while in their service dept., the CEL comes on. They read the codes and it's got an intermittent misfire on two cylinders. On these V12s you don't even feel or hear an intermittent misfire. This dealer isn't familiar with Aston's, and when I explain it will probably require new coil packs and how much labor is involved to fix the issue (parts are fairly costly too), they are shocked. They state they can't (or don't want to) tackle that job.
Long story short...........I tell them I now don't want the car, and they say they will refund my deposit. I'll give them credit for being up front and honest about the situation. An unscrupulous dealer would have just cleared the code and sold me the car. For all I know, maybe the individual they got the car from did just that. Unlucky that it happened, but very lucky it didn't come up after I'd owned it for a month.
So..........back to square one. The search continues, but there are plenty of DB9's on the market. Even a few DBS's.
Bullet dodged. Although, that servicing is not as brutal as "Tavarish" purports it to be. We need to understand it's part of a DIY Youtubers shtick to present it that way. One of the plugs is really back there, so small hands help with that one. The biggest issue with misfiring on these things is that the precats can disintegrate, get sucked back into the lump and totally bodge it. It's most common symptom is a misfire. That would be a costly repair as you know.
I too didn't wind up with my deal from Cars and Bids. Scummy high bidder and seller. The original high bidder (who walked away then reappeared) wound up with the car or so I'm told. Thats OK, plenty of DB9's out there.
There are quite a few videos out there on these things, particulary from Bamford Rose (Indy AM specialist in Limeyville). Notwithstanding the precat issue, these engines are bulletproof and decidedly tunable (DB9 is essentially a detuned Vanquish lump) if that's your thing. Suspensions are suspensions with the only issue I can think of is finding appropriate bushings. For me, the biggest issue is odd things like the amplifier in the Linn equipped cars as they go. They can be repaired for a couple hunnert bucks or replaced for $3k and have the same issue down the road. Oil filters are $60 (used to $15~ Hengst or Mann for the nazimobiles) which burns me and not exactly easy to access from what I've seen. Trannies are ZF's and very easy to service (my old BMW 745Li had the same gearbox). Filter assemblies are $100 and solenoid gaskets/seals are dirt cheap. In my BMW I replaced all of the above with Valvoline tranny fluid from wally world for $150.00 all in. It went from wonky and slow to crisp and quick. The dealer told me a new tranny was necessary. The biggest issue with these things is the bespoke interior and exterior bits which are quite dear. Not unlike a Bentley's unique parts compared to the Audi operating gear.
I will say this, V12's are intoxicating, if you haven't had one. I've got my S600 and former S65 with a V12, they're both violent and benign/sedate/reserved simultaneously. My CL63 which has a black series top end and more horsepower isn't as intoxicating as the 5.5l biturbo V12 in the S600. The V12 just teleports you. You want to go 140? Give me but a moment and you're there. Having driven several AM V12's, it's quite similar to that, only a little more violent/responsive and certainly more aurally enjoyable.
Onto the next chase... The good news is that certainly at this time of year the market is on the downside. Also, every tard on the planet has maxed out their ATM, AKA HELOC.
