By fpena944 - Mon Dec 18, 2023 9:26 pm
#247898
Went on a quick errand and when I got back in my Cayman the instrument panel told me there was an ABS, PSM, and PDK failure. I freaked out a bit but it did say that I can still drive but just to be careful. Since I was only about a mile from home I hurried back but the whole time the car kept misfiring badly.
Hooked up the Durametric and got all of the following codes:
P1700
C1600
P1800
P0600
U0418
P1990
P199A
7010
2125
a221
a008
a016
Since it was a cold and miserable day and everything lit up at once I chalked it up as an anomaly, cleared the codes and the car went back to normal again.
Then this morning it did it again. So now I know something is going on. I started looking up all of the potential causes and found different solutions like battery replacement, brake switch, ABS sensor, bad coils, and even bad PDK itself.
Went to my dad's and hooked it up to his Snap-On diagnostic and this time we got a misfire on cylinder #6. Cleared codes again and in seconds the same misfire.
So I just ordered new coils and plugs. Hopefully this will do the trick but if any of you have observed similar symptoms, let me know what you did to resolve them.
Parts arrive later this week so by this weekend I should know if this solved the issue.
P1700
C1600
P1800
P0600
U0418
P1990
P199A
7010
2125
a221
a008
a016
