By worf - Sun Dec 03, 2023 8:14 pm
#245830
Measuring thrice required to make sure the first cut doesn’t cut too much.
Also, best remove the front cover for this. Much easer to get to that stuff for fettling.
PorKen wrote: ↑Sun Dec 03, 2023 6:48 pm I plan on making brackets to hold the 'wishbone' carrier, ditching everything else. Unfortunately, there are not many mounting points inside the fender, using existing bolt holes.Take the two outer sections of the lifter bar, chop-off the ends that protrude into the engine bay, weld a plate to the shortened sections that’s the same shape as the plastic bearing, and then use the holes for that bearing in the chassis to bolt the welded section in place.
My 928 Inspection Guide
