By Benno - Mon Oct 09, 2023 1:16 pm
#237959
I have some general questions about engine modes, larger pistons, stroker cranks, and the interplay between cams, valves, and intake. I am in the middle of an S4 motor rebuild. It's my first motor rebuild and I have lots to learn and even more questions. My plan is to rebuild the motor stock-ish because I am mostly scared of getting in too deep. However, as I learn more about mods I am feeling more comfortable with them.
I need to repair one cylinder. my options are to oversize that piston (1st oversize). Alternatively, I can have the all 8 cylinders bored out 5mm larger and use the 968 pistons for a larger displacement motor.
Here are some of my questions:
1. Will this block (1987/Squirter) support remove 2.5mm from the cylinder walls? I understand the S3 blocks have thicker cylinder walls and are ideal for this. But what about the later blocks?
2. Is a stroker crank required can I use the stock crank (78.9mm stroke) which would yield a 5.4L motor? Is there a downside to expanding the bore without expanding the stroke?
3. Do I need different valve sizes? The S4 and GTS share the same valve size between the 5.0L and 5.4L so I am thinking the valve can remain.
4. Do I need different cams? I would assume I would need different cams to take advantage of the increased displacement. But not sure which direction to go. The GTS cams may be a good option but my understanding is those are optimized for torque which is a byproduct of longer-stroke engines. I could use some education on this topic.
5. Is the stock intake going to be the restrictor here and is adding displacement even worth it with known restrictions in feeding air into the engine?
Thanks for letting me ask these very rudimentary questions, I appreciate whatever knowledge you all can share.
