By David993S - Tue Sep 12, 2023 5:23 pm
#234030
Odd thing happened about an hour ago. I started the 993 to move to the driveway to wash it. I thought the key seemed a little "notchy" when turning. Shut off fine. Started up again fine. Go to turn the car off after putting it back in the garage, and the key is stuck in the ignition. Won't turn all the way off (verticle position) to remove. I can still start the car and shut it off, but the key is stuck in the ignition. It's stuck in the first position - the one that dings when you open the door.
It doesn't have anything to so with the steering wheel lockout mechanism. That was disabled 24 years ago when the hand controls were installed. And it's worked fine for 24 years. I tried turning the steering wheel lock to lock to see if that worked.......nadda. The car has 46k miles.
Anyone ever have this problem? Do I need a new key/ignition mechanism? Did the tumblers inside the ignition break/fail?
Any advice, good or bad, is welcomed.
