By WyattsRide - Sun Aug 13, 2023 12:30 pm
#229538
Needed to replace the short fan belt. I removed the Throttle linkage bracket from the fan bracket.
After putting everything back together I started the car and after giving it some gas the idle stayed high. It stayed around 1900. The Throttle linkage seems to be sticking and not going back into idle position. It will, if I give the linkage a little nudge. I took the linkage apart, cleaned everything, polished the shaft and put a little high temp grease on it. That helped some and let the linkage return back to idle position some. That let the idle return down to about 1100 after letting off the gas. Before this the idle was always around 750-800.
Before doing anything else, what thoughts does the brain trust have on this?
(throttle connector bar off the linkage ball)
Thanks
Thanks
Thanks
Rick
1985 Schwarz/Burgundy / 5-speed /X-Pipe and no Cats
"Porken S300s Chips, Dips, Chains and Whips. You know, your basic HS orgy type things" - Lisa (Weird Science)
Rick
