By ladybug83 - Tue Aug 15, 2023 1:18 pm
#229753
While testing the coils on my ‘85 S2, the primary resistance is reading 1.0-1.1ohm on both coils, which is above the WSM range of 0.4 to 0.7ohm.
Secondary resistance readings are both 6.1k-ohms, which is in range.
Both “seem” to work fine, but are of unknown age. Planning on replacing both when they become available again from Porsche (they indicate Q3/2023).
But scratching my head on the above-range primary resistance readings.
Any thoughts?
Thanks in advance.
Josh
Any thoughts?
Thanks in advance.
Josh
1985 928S C99 ROW Twin-distributor 16V 5.4L "GTS-inspired" Stroker w/ LH-jet 2.3
Out here in the fields I fight for my meals I get my back into my living, I don't need to fight to prove I'm right I don't need to be forgiven ~Pete Townshend
@SoCal928s
Www.SoCal928s.com
https://www.youtube.com/watch?v=ln33GoDs6ig
@SoCal928s
Www.SoCal928s.com
