By gregn928 - Wed Jun 28, 2023 8:35 pm
#222642
While beginning the process of replacing my front right ABS harness, I discovered that the connectors in the engine compartment had become so brittle with age and heat that they are disintegrating with even the slightest movement:
Does someone have some wise advice on how I should proceed?
I'm also noticing that there is not much clearance between where the ABS harness passes through the fender wall and the two A/C lines that run right by that same location. It seems like it will be a real challenge to push the new connector through from the outside:
Replacing the font left ABS harness was so easy that it was almost fun. This front right one is the opposite of that!
Greg Nichols
1987 928S4 5-sp, Venice Blue Metallic
