By Crumpler - Mon Jul 03, 2023 9:40 am
#223375
Hey guys, some input if you have a moment.
I have had ‘observations’ about the S3’s braking for awhile.
I don’t know if soft is the best word, the pedal travel seems long before they bite. The pedal does not slip towards the floor when braking — like MC failure.
There is no squirrelly behavior, stock brake bias and booster.
Brake upgrade to GTS on front, but issue predates that.
I would say generally, the first 1/3 of pedal travel has no real resistance. You can feel braking start around 1/2 the travel, and biting hard at final 1/4.
I gotta power bleed and change fluid again for the track inspection, I will let you know if any additional air found.
I have not driven any other 928’s, only mine, is this what brakes did in 1986?
I have a rebuilt MC here in a box assuming it would have to be replaced sooner or later but where would you go with this first?
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
