By Benno - Tue Jun 20, 2023 3:20 pm
#221294
Since this forum is a safe place to discuss vacuum pumps, I thought I would share some information.
Take a look at these before and after shots of the pistons heads of my 1992 GTS (cylinder 5-8 only for now). The before shots are with the vacuum pump system installed (50K -70K miles). The after shots are of the last 3000 miles without the vacuum pump system and using the late GTS breather system. Oil baffle under the OFN in both cases. I was shocked to see so much oil caking on the piston heads in such a short period of time.
Also I am seeing quite a few knocks under load indicating the octane decrease from oil injection. Timing and plug condition verified.
I thought I would share this information because it shows just how much oil is going through the breather system on an early GTS. Also, I noted more oil consumption and more oil collecting in the plenum after removal of the vacuum pump.
Some background: I had removed the vacuum pump system because the Provent 200 air oil seperator was being overloaded and I was getting oil mist over the front of the engine. This was made worse after I converted the Automatic transmission to a 5spd and now have more time at higher RPM's which produced more airflow output from the vacuum pump and more oil mist on the engine face.
I am thinking I should re-install the vacuum pump and try to solve for a high flow filtration system. I would appreciate some suggestions on high flow oil separation systems. Here are the air flow rates for my vacuum pump.
I am looking for a separation system that is free flowing or can handle up to 800 LPM flow rate. I would prefer to keep the system closed loop if possible but would consider something that offers a blow off above a certain airflow.
