By hernanca - Sun May 07, 2023 9:31 pm
#214567
Same as I posted at TOS:
I have one 7x16 928 Phone Dial wheel.
I would like to have another, or two more (so I have a spare).
One might think I have a bunch of them, but all except that one of my many wheels are early & late 944 wheels, plus a set of the flat phone dials (15's). I would like to get closer to the front wheel et65, than what I see with the late 944 fronts I typically run (et52.3).
I know they are verboten on the 86.5, but I test fit the one I have and if I add the 3mm spacer that was mentioned (I believe by hacker on TOS), I will clear the brakes.
I already reached out to 928 International (Mark only has some wonky ones that he is going to take another look at).
Let me know what you got, where you are located, and whether you might be going to the Columbus, OH Renndezvous!
Thank you, in advance!
Carlos Hernandez
Silver 86.5 928 S Automagic
w/ Stroker Motor (in tuning prep)
928OC Charter Member
http://www.928oc.org/
