By sh944 - Fri Apr 21, 2023 11:02 am
#211579
SO, when I got my wife's 928 back from an aforementioned shop, amongst the many deficiencies was that when you go to adjust the side mirrors using the toggle switch, they both move independently (one goes up and down while the other moves side to side), and the rocker select switch does nothing. Clearly its mis-wired and no one bothered to check their work while at the "professional shop" (you'll see this is a recurring theme from the various posts I will be making about repairing the car).
Does anyone have a wiring diagram for installing newer mirrors on an older car handy? I can figure it out myself if need be but if someone can save me some time, it would be appreciated.
Following the path of least resistance to the lowest common denominator since 1961... My pronouns are “curmudgeon”, “geezer” and “I don’t give a shit what yours are”. "Designed by clowns who are in turn supervised by monkeys" doesn't apply to just Boeing
